5G Broadband - 5G Smart Hub - HH20C- Outside Ariel?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
17-10-2024 01:51 PM
Hi
I got 5G Broadband from EE, using the Smart 5G Hub with the model: HH20C.
It is possible to setup a ariel outside and if so, can EE do this for me and what does EE charge to do this?
I can't see any ariel connections on the Hub.
Regards,
Gaz
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
17-10-2024 04:47 PM - edited 17-10-2024 04:54 PM
Thanks for reaching out on the Community @GazCBG
The Smart 5G Hub HH20C doesn't come with connections for an external antenna, and so we also no longer offer an antenna fitting service.
For optimal signal, try place the router by a window, preferably in the same side of your premises as the local or best suited mast. This may take some trial and error. Though you can contact Customer Service technical team who can point you in the general direction of your best mast.
Some customers opt to purchase their own routers which have the hardware specifications they are looking for, and install their own external antenna. This is not something we would be able to provide support with though.
There are some community pages you can find with users discussing their choices.
Hope this helps.
Ali
- BT to EE transfer in Broadband & Landline
- Should I upgrade from BT to EE Broadband? in Broadband & Landline
- Hub power supply broke in Broadband & Landline
- Full fibre cables cut liskeard two weeks in Broadband & Landline
- Homebrew Smart Hub Pro upgrades from Smart Hub Plus - will it work? in Broadband & Landline
