on 30-04-2021 09:37 PM
We have had a 4g ee router for a couple months with no issues. Recently both netflix and amazon prime will not work on smart tv or firestick. Internet speeds are fine and netflix through phone works fine. I have tried resetting the content control with no success. How can this be resolved?
Solved! Go to Solution.
on 18-05-2022 02:40 PM
@EssexBoyEE haha what you have recommended seems to have done the trick!! I have no idea how this has helped but thank you so much!!!! I will test this out for a day or so and see how it goes and get back on here to update 🙂
18-05-2022 05:38 PM - edited 18-05-2022 05:46 PM
Glad to be of help, let us know how you get on in a few days after your Tests
15-07-2022 06:10 AM - edited 15-07-2022 06:11 AM
Thanks - as a total newbie can anyone explain how to actually access these setting on the router?? @EssexBoyEE
on 15-07-2022 11:34 AM
Welcome to the community.
Which router are you using?
Are you having problems with your router?
on 15-07-2022 09:34 PM
Hi Leanne
Yes same problem as described in the thread, however none of the suggestions seem to solve my issues.
Router is 4GEE Router
model D412C57
on 16-07-2022 09:14 AM
It may be worth speaking to our Technical Support team to make sure everything is OK from our side. They'll be able to send a network refresh through to your SIM card too.
on 15-08-2023 02:36 PM
Hi
I would like to add to this.
I have spent 3 days trying to sort the same problem with no joy. I also fin this morning that Microsoft Teams did not work with the ee data sim, so I lost a days work.
Numerous calls to ee and visiting an ee store did not resolve the issue. Using and O2 or Smarty sim worked perfectly.
I strongly believe there is s problem with the data sims from ee.
As a result, I've gone to O2, and although I'll miss the speed of the ee sim, if it doesn't work properly, it's no good to me.
Ee need to sort this.
Mike
