on 29-05-2023 09:45 PM
I always change the default password on a router, but when I went to the routers management page & it only gives me the option to change it before I can do anything, thats a bit authoritarian isn't it? Now I have changed the password, I went back to the management page today & it didn't recognize my new password or it's old password. This is absolutely rediculous, but nothing I shoudn't expect from BT. Will pressing the reset button reset it to it's old password, or just other settings?
on 30-05-2023 08:55 AM
Thanks for coming here.
Can you try using admin as the password when you access the management page. Does this work for you?
Leanne 🙂
