4GEE router not allowing certain websites
RJH75
Recently started using a 4GEE router and I have set a few routers up in the past so know my way around them fairly well. That said, it is blocking certain websites - I'm assuming because of "adult content" (no - not porn). Ordinarily I'd be able to allow websites through a firewall but cannot see a way around this. At almost 50yrs old I think I'm more than capable of making my own decisions about what websites I can visit!
Any suggestions?
EssexBoyEE
Your Routers hardware will not be Restricting access to Adult Content, this will be your Sim Number Account settings if set to On.
If youve set up an Online Account, you can change the Settings buy either use the EE App on a Phone that is connected to your Routers WiFi or go to the My EE Web Dashboard here -
https://myaccount.ee.co.uk/app/controls
Northerner
Hi @RJH75
Remove the content lock on your SIM
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
