on 08-05-2023 12:58 PM
Hi there,
Trying to get into router settings on my 4GEE and when I type in 'admin' it doesn't recognise the default password. How to I get into my own device? I want to experiment wiht different Channel settings to see if it wil help my SmartTV connect to it. Any help gratefully received.
Solved! Go to Solution.
on 08-05-2023 01:43 PM
"admin" is not the default admin pwd for the 4GEE WiFi but the admin password found under the battery cover.
on 23-03-2024 01:51 PM
This is incorrect, there is no battery cover. The 4GEE router is mains powered only.
23-03-2024 01:56 PM - edited 23-03-2024 02:03 PM
@Spinner72 : I think you are talking about the 4GEE Smart Hub which this thread wasn't about.
