24-04-2023 06:12 PM
Hi all
The wifi password has been lost and the only instructions i can find online tell me to login to the 4GEE WiFi Mini router and change the password. But I'm not sure how I can login to the router if I'm not connected to it first??
Any suggestions is very appreciated
24-04-2023 06:14 PM
Connect to it by USB 1st.
24-04-2023 06:45 PM
Thanks for the message Do I need to download some EE software to do that? Plugging it into my laptop didn't auto boot anything. Couldnt see a way of connecting.
24-04-2023 07:19 PM
It should come up with a notification to offer to load a Web Connection Drive & then install itself from the device itself. When you connect you should see it listed under the "Safely Remove Hardware" icon.
		05-08-2023
		02:18 PM
 - last edited on
		05-08-2023
		05:40 PM
			MikeT
please i have problem with my mini wife i lost the back cover and i dont know the password in mind pls any help pls
imei number xxxxxxxxxxxxxxxx
05-08-2023 03:21 PM
it not working that why let just give our code so you will help as
05-08-2023 05:36 PM
@emmaunel1 : This user discussion forum does not keep pwds of devices. You could try to raise this with CS. They might have access to a record of them but I doubt it.
06-08-2023 07:52 AM
Hi @emmaunel1
If you're unable to change to code following the instructions above, try speaking with our customer service team who may be able to help.
