4G wifi not connecting to Samsung smart TV
chvrloo
Recently purchased the 4G broadband hub and we are unable to connect it wirelessly or wired to the TV. It will connect to the network but not to the actual internet. We got an ethernet cable to connect it and it shows as connected but will not connect to the internet.
6 REPLIES 6
Rach_H
Hi @chvrloo,
Welcome to the Community!
We don't want you to have any trouble connecting your devices, so I'd be happy to help you with this.
Are you able to connect other devices to your hub, or are you also having difficulty with this?
Rach
Yes phones, tablets and laptops are connected fine with no issues. We called EE who said the wireless signal may not be compatible with the tv, hence why we got an ethernet cable but still not working
Rach_H
This does seem odd @chvrloo.
Have you been able to connect the TV with another network previously?
Rach
We have just moved into a student house so this is the only wifi we have access to so not sure if it connected to another wifi beforehand. The TV will connect to a hot spot from a mobile so pretty sure it’s the wifi box that’s an issue
Rach_H
It does seem odd that it will still connect to other networks, and also that you can connect other devices to the hub @chvrloo.
I'd recommend giving the team a call, and letting them know everything you've already tried, and they can work with you to get everything up and running.
Rach
Catelil
I couldn’t connect my  TV  to APPS  although connected to internet after I moved house.   Tried all advice given and as last resort done a factory reset which wiped APPS off.
I signed into Samsung account online and I signed into APPS from my tablet which ( miraculously ) synced APPS  back to my TV . Not sure how it works but it did, scanned the link on camera from my phone and signed in that way. I’m not technical at all but this brought everything back to TV like it was before I moved house.
