4G WIFI PAYG
KRazey09
I have purchased a new 4G PAYG Wifi device. Is there an app i use to top this up or see how much data is left etc... I have the EE app but can not see where at register this device?
11 REPLIES 11
I have just purchased the 4G PAYG WIFI device. It comes with 120gb data.
It says it will send me a text when abroad to activate the roaming charges etc... how do you see these text? as this is just a box, no screen?
Leanne_T
Hi @KRazey09
Thanks for coming here 🙂
If you have an existing EE account, can you link the number for WiFi device to your account?
You can view remaining data by visiting add-on.ee.co.uk when you’re using the 4GEE network on your device or tablet.
Speak soon.
When I try and link the number it says it will send a text to confirm. But i do not know where I would access the texts
Leanne_T
Thanks @KRazey09
Which 4G WiFi device do you have?
Most mobile routers can receive texts. Login to it & look for the SMS Section/Inbox.
I do not know how to login to it?? there is no instructions?
Where do I login? when i tried to open an EE account it asks for the mobile number of the device which i give then says will send text to confirm but I do not know where I would find this text? therefore i can not open an EE account?
I think I may just return the mobile device as it is very complicated
Hi Leanne,
I have the EE PAYG 4G Mobile WiFi 120 GB
Kelly
Leanne_T
Hi @KRazey09
On a device connected to the WiFi, go to http://192.168.1.1 and enter the username as admin and the password as admin, or use the admin password under the battery cover.
Does this work for you?
