on 20-06-2024 09:02 AM
When I took out my EE Smart Router Broadband contract it came with a small EE mobile router. This I used when we went on holiday or to areas where my tablet wouldn't work. After a while the unit comes up with the message that I need to purchase more data. That's not a problem but I cannot find out how to top it up - can anyone point me in the right direction or do I need to purchase a new dongle from someone like Amazon
Solved! Go to Solution.
on 20-06-2024 10:21 AM
Mobile routers contain a SIM. All SIMs have a mobile no. Visit http://add-on.ee.co.uk/status from a device connected to your mobile router by WiFi to see your data & credit status as well as its mobile no. at the top.
on 20-06-2024 09:06 AM
@Vennwood : Try using Fast Top Up online with a UK bank card. You don't need to login or register anything. All you need is your mobile no. & it doesn't remember your card details.
on 20-06-2024 09:17 AM
Just a little confused by this. The router came as part of my broadband package which is separate from my mobile phone contract so how do I know it will top up my router? I use the router mainly for two tablets as our phones have enough data
on 20-06-2024 09:35 AM
I'm not talking about your mobile phone. You just need the mobile no. of the SIM in the router.
on 20-06-2024 10:19 AM
Ah - not sure what that is as there was no information with it. I still have the box so will see if I can find the number. Thanks
on 20-06-2024 10:33 AM
Many thanks - all sorted
on 20-06-2024 10:38 AM
