on 15-04-2024 12:03 PM
I have a Ezenos 4G Industrial Router which will work happily with an Asda Mobile (Vodafone) SIM and give Internet access. I have a known good EE data SIM (proven in a MiFi unit) that will attach to EE (Router admin page showing EE LTE and signal bars) but does not give any data connectivity. I've spoken with EE tech support who confirm I have the correct APN settings and can see the SIM. I've done a complete default settings reset on the router and re-entered the APN data but to no avail. On the admin page dashboard the WAN4G is showing not connected for EE but connected for Asda mobile. Any thoughts please?
on 15-04-2024 12:36 PM
@Battwave : The router is locked to Asda or maybe Voda. When did you buy it new?
15-04-2024 12:51 PM - edited 15-04-2024 12:53 PM
That's possible, but I'd have thought the EE SIM wouldn't attach to the network if the router was locked. Is that correct, or will it attach but not connect?
Is there any way of unlocking it please?
The router is an Ebay used purchase so I've got no idea how it was supplied. Is locking normal for industrial routers?
on 15-04-2024 12:57 PM
To unlock it you'll need to apply firstly to Asda & then maybe they'll put you off to Voda.
on 15-04-2024 01:07 PM
Thanks, will give it a try.
