4G / 5G Rooter Recomenations
GreaseMonkey
Hi I'm looking for peoples opinions on the best 4G or 5G modem / rooter i can use. The servie in the aria i work hase gone alfull (it used to be pirfect but over the last 12 months its gust getting worse and worse) so im hoping there is a modem / rooter that can help.
I currentyl have the netgear Night Hawk M1 and im looking for somethng with better range etc
I'm a mobile mechanic and require wifi out on the road, I'm looking for smething i can put in my van with great range both for.
I can fit arials to the roof of my van thats not an issues to increase signel.
I'm basicky stuck without internet on the road All the computer equiptment / software requiers internet to work,
If anyone knows of some GOOD kit that i can use i would be gratefull
Many thanks Lee
Northerner
Hi @GreaseMonkey
You've already got a great modem. Your issue sounds like network coverage.
Is your core usage when you're out in the van or when at home/both?
I'm having a really odd coverage issue out and about.
If my signal drops to 2 bars or -110db data becomes unavailable
Download still works ok, the issues is upload is 0.11 mbs or lower whitch
means the software can't function
With that when making calls I can hear people perfectly clear but they
can't hear me. (Have the same issue with 2 different phone brands that I
own)
EE are slaying there is no network issues or service issues. But something
has changed for things to get this bad, Like I said it used to be fantastic
not had a real issues in 10 plus years of using EE but now it's at the
point over the last 8 months to a year it's just got gradually worse and
worse to the point it's not usable.
And the times I have a good enough signal for everything to work is getting
less and less frequent
I've had replacement sim cards new phone new 4G card in my laptop there all
still getting the same issue
There does seam to be 2 antenna ports on the modem do you know of any good
antennas that may make things better for me
Thanks Lee
