Re: Ps5 portal
Demai-Jeffers
I’ve got a ps portal and when I try use my EE hotspot the data never works. It says can’t find connection. I just don’t understand why EE would sell ps portals for they’re phone data to not work as a hotspot
39 REPLIES 39
Jamie614
Yeah I have the same issue. No way round it either. I believe it’s because of the NAT type EE use, it doesn’t support online gaming.
Amespenny
Valued Contributor
Valued Contributor
Why didn’t you start a new thread for this as it’s a totally different issue?
otherwise it does work I’ve hotspot mine a few times when I’ve been at the airport and whatever else. The signal needs to be strong. If it’s less than full signal you’ll have lag anyway and it’ll be frustrating to game regardless. It’s also a Sony product… not an EE product so its functionality isn’t anything to do with EE. EE sell PS5s and Xbox x’s as well so saying you can’t use EE data is such a stupid comment to make. Play the portal off the WiFi at friends/relatives homes or when you’re abroad. It’s not really suited for on the train or whatever
Leanne_T
Hi @Demai-Jeffers @Jamie614
Thanks for coming to the community, I have created a new thread for your query.
Can you connect the PS5 Portal to any other WiFi network?
Can you connect other devices to your hotspot?
Hi @Leanne_T
Yeah, normal hotspotting works fine, it’s just the portal. From looking at other forums it may be because of CGNAT which doesn’t play nicely with remote play.
no idea how @Amespenny has had success when everyone else I can find online has issues. I’ve tried a few times with full signal and fast 5G connection.
it seems to be common with a couple of other mobile providers too so I may have to get an O2 sim for hotspotting.
Leanne_T
Hi @Jamie614
Have you reported this to our tech guides on 150?
Jordan-1
2 weeks ago I could use my ee hotspot on my portal fine switched provider from 3 because that wasn’t working but now I can’t connect to ee hotspot atal on my portal
has anyone got a fix?
Katie_J
Hello @Jordan-1
Welcome to the community.
Are you presented with an error message on the device you are trying to connect?
Katie
Yes I get a connection error only when using EE hotspot my home internet works fine and I’ve used a friends three hotspot and that still connects will this be fixed?
Katie_J
Thanks for getting back to me @Jordan-1
I am unsure on this one, I would recommend speaking with our tech guides on 150.
The team will have access to all the relevant systems to be able to complete a diagnostics.
Katie
