on 27-11-2023 11:05 AM
Solved! Go to Solution.
on 28-11-2023 07:44 AM
They should be able to reset your online account completely so that you can register again, @robpec
on 28-11-2023 10:00 AM
Hi, Yes, they reset it. I registered my account again but the problem is the same. I cannot register devices because I get a message that the devices are already registered on another account. It's been over 3 months now, I've been paying bills and I don't know why?!
on 28-11-2023 12:49 PM
They may need to reset the ones that the other numbers used to be attached to, @robpec
Do you know if they tried that?
on 28-11-2023 03:48 PM
Yes. My last interview was on Saturday (25/11/23). I was told that my email address had been reset and I needed to register again. I did that but the account number remained the same and there is no device
on 28-11-2023 04:11 PM
OK, thanks @robpec
This is something you need to discuss with our technical support team again. If everything they have tried doesn't work, they can raise a ticket to investigate it further.
on 28-11-2023 05:44 PM
This has been going on for over 3 months now and all I have are text messages about the ongoing investigation. If it helps, this is the investigation number INC2736103 Please help because I don't know what to do anymore 😭
on 29-11-2023 09:29 AM
OK, thanks @robpec
I've sent you a private message to try and get you some help with this. Please have a look and get back to me.
