My EE app not working on iPhone and ipad
claretfc
Hi, my EE app no longer works on my iPhone and ipad. I am unable to sign in and manage my account and I have to access EE web on my pc and that is a little difficult as it keeps crashing.
I have twice spoken with technical support and was told it was a known fault and it should work again in “a couple of hours”. That was 5 days ago. I have seen the app work perfectly on android and wonder if it is an IOS issue.
Has anybody any thoughts on this?
Nick
14 REPLIES 14
Problems are the same as other posts
The ee app does not work and your response has not provided any resolution
Christopher_G
If you're still having problems after deleting and redownloading the app, I recommend speaking to our Technical Support team, @Malbec.
Hello Christopher_G
The problem is quoted by many users and none have replied solved by
talking to tech support
If tech support have an answer they should make a solution available
online to all
My problem is all of the Q's and A's end up with this or a similar statement
No listed resolution
Glenafton1967
iPhone too, not connecting to app and rewards app. When go to click, it kicks me out of apps
@Glenafton1967   The app works fine on my iPhone.     What rewards app are you referring to ?  And have you entered your number on that rewards app.
