18-07-2025 11:07 AM
Has anybody found a way to export their contacts from the EE hub? It is shown in the Help Documentation that there is an Export and an Import function which was available on the old BT Hub. I recently had an EE Technician exchange an EE hub that would not connect to the Hybrid Connect unit and I lost all my 200+ contacts! I am currently reinstating my contacts and want to save them in case something similar happens again. EE Customer Services are hopeless and have no ideas! This is surely a basic function that should be there as indicated by the documentation!
18-07-2025 12:15 PM
@duncanC45 What EE Router do you have!
18-07-2025 06:17 PM
It is a Smart Hub Plus type SH31B.
18-07-2025 07:12 PM
@duncanC45 That specific hub has never had the ability to export contacts!
18-07-2025 10:49 PM
That just seems ridiculous, the Help documentation says you can do it, the old BT hub did it, this one I should think you could claim is not fit for purpose! A major failing on the part of EE. But thanks for your input.
19-07-2025 08:37 AM - edited 19-07-2025 08:41 AM
@duncanC45 No problems, few error's and dislikes to what the latest and greatest cannot do! And one off the reason's that the Factory Reset is a killer as it wipes all you have done since your re-load and newly applied contacts and with NO Backup even for the Router starting from scratch is all you can do!
20-07-2025 07:38 PM
When I was moving from BT to EE and digital voice I created a vCard file containing all the contacts I wanted. This was imported into the Smart Hub Plus to provide the initial contact list. When I add/delete/update the contact list in the phone I also make these manual changes to the vCard file so that if I have to factory reset the hub I can then reimport the vCard file.
The vCard format can be found on the BT community here Digital-Voice-Contacts in message #8.
06-03-2026 03:35 PM
just to add to this...
EE wanted to replace my Hub (due to an unexplained issue)
When I discovered that some tech muppet had removed the option to EXPORT all my contacts I canned the replacement.
I have today escalated to senior management and then to Product team WHY ON EARTH do you have the ability to import, but NO (ZERO) ability to export.. - otherwise I loose ALL my contacts.
At one point the tech team said "buy a new panasonic digital phone and store them there... rendering the BT/EE handsets next to useless...
SO how is that going to allow me to recognise, divert/allow calls!
So OFCOM will get a message if the Exec/Product team cant get think this one through...for heavens sake I can export all my setting from my phone, my NAS my PC - but EE hub NO!
UPDATE
OMG you can no longer EXPORT your HUB config - so if you have pre-set ip addresses and VPN settings...
NO!
EE Community
06-03-2026 03:57 PM
@ordessa The wonderful world of a replacement EE Hub and has not supported Backup for years!
