ADSL BT SPLITTER - Leave in socket or remove, switching to Digital Landline ?
Blox1
7 REPLIES 7
@Blox1 : You shouldn't need it.
Mustrum
@Blox1   it really depends on the connector you have to your router.
Normally you need something to convert the RJ11 DSL cable to the phone socket - the ADSL filter cable does this for you.
Do you have another way to plug your FSL cable into your phone socket?
@Mustrum : The Phone socket on the router takes a standard BT phone plug. It doesn't need a DSL splitter & if you use 1 it'll just be passthrough. You're not plugging a DSL cable into the phone socket; you're plugging a phone.
Mustrum
@XRaySpeX   Where does the router plug into?
@Mustrum : I thought the OP was asking about the Digital Landline. Yes, if the OP has a DSL BB connection the DSL splitter will still be needed at the master BT phone socket to receive the DSL cable from the router.
Mustrum
@XRaySpeX  so there you go, I never mentioned the phone connection, only the router connection.
@Mustrum : OK!
