06-06-2022 08:16 PM
So I was told by an advisor to avoid bank charges to cancel my direct debit for this month so I have done this that's all fine what I'm wondering is does this permanently cancel the direct debit or just this month's as this month's has already been paid for for context I bank with Halifax I'm just wondering on the EE system it still says ¹1I have a direct debit with the correct details my question is will they try to take next month's bill as usual or will I need to set up another direct debit this shouldn't be the case as it's still on the system
06-06-2022 08:59 PM
You were ill-advised. When you cancel your DD you cancel it for good. EE will try to take your next bill from it & it will fail, marring your credit record & attracting a non-payment fee.
You should go into your MyEE & change your method of payment to a bank card or reinstate the DD.
06-06-2022 09:07 PM
I have looked on the my EE page and it still says my same direct debit details so what should I do just retype them in I'm not sure what to as I'd the details are already in what do I do
06-06-2022 09:56 PM
So.i have been told by and advisor to wait two days and then once it has cancelled on their end just re enter my original details as this creates a new direct debit is this correct?
06-06-2022 10:27 PM
You won't be able to create a new DD mandate until the existing one has fully cancelled and your payment method is therefore not direct debit.
07-06-2022 06:21 AM
Ah I see so obviously the bank has said to wait two days before it will be cancelled once this is confirmed from ee can I use the same bank account I used previously as I dont want to change this
07-06-2022 06:22 AM
What I mean is once creating a new direct debit can I put the same details again
07-06-2022 06:37 AM
Yes.
07-06-2022 07:08 AM
Cheers so simply I just need to wait until the bank let's ee know I cancelled it then I can re enter my details and create a new direct debit
03-11-2022 07:24 PM
how do you cancel dd
