30-10-2022 08:58 PM
Hi
Hopefully I can explain this well enough.
I have 3 mobile phone contracts with EE one of which is now out of contract, would it be possible to swap numbers around?
I basically want a number that is still in contact swapped with the contract that is now expired so that I can transfer it to another provider when I start a new contract with them? Is this possible?
Cheers
30-10-2022 09:05 PM
@Patters1978 No that’s not possible as it will terminate that contract. Any number that’s moved will cease that contract.
If you move the out of contract number to the in contact tariff you’ll loose the number it replaces.
If you move the in contact number it will automatically terminate that contract.
30-10-2022 09:05 PM
