International dialing add on
Graeme261
I have purchased an international dialling add on in order to dial Australia from the UK ( 500mins, £14). I did this a couple of weeks ago and it is showing as an active add on.
When will it start to work?
1 ACCEPTED SOLUTION
Ali_A
Hi @Graeme261
Once the add-on is showing on your account, it means it is active and ready to use.
You can keep a track of the minutes remaining using the EE app. Or text AL to 150.
The 500 international minutes is a monthly recurring add-on which you can cancel when you no longer need it.
Ali
Ali_A
Hi @Graeme261
Ali
