How do I get to speak to a human being?
Mull1gm
I've been trying to find a way to speak to a PERSON re a recent (disappeared) text re 30% increase in charge for mobile.
Alex_H
Hi @Mull1gm,
Welcome to the EE Community
You can find the numbers to call us on our contact us page. If you select option 1 when calling you will get a text back to use our visual menu and just select the option to talk to someone about your bill. Or you can press option 2 when you call to use the traditional audio menu to select who you need to talk to. They will be able to check regarding the text message you received.
Alex
Alex_H
Hi @Mull1gm,
Alex
@Mull1gm  You call customer support on 150 and select option 2 then listen to the other options given and select the closest to your issue.
