on 11-02-2025 09:02 PM
So I've changed my direct debit which is due on the 15th to the 28th the same month but it's still saying the 15th will I get charged twice?
Solved! Go to Solution.
on 12-02-2025 08:50 AM
Hi @Cleggers94
Welcome to the community.
If the bill had already been created before you requested to change the payment date, it would still be taken on the 15th for this month as @Chris_B mentioned.
This could then mean there is another bill on the 28th, although it would be a much smaller bill for a part month.
If you wanted to check exactly how it would impact your bill, our billing guides are available to check your account.
Michael
on 11-02-2025 09:09 PM
@Cleggers94 If you’ve already been billed you can not change the date. The process has already begun to take payment. You also need to give 24 hours for your account to update
on 11-02-2025 09:13 PM
Thanks Chris I just don't want to be charged twice that's all
Hi @Cleggers94
Michael
