Call log for September 22nd 2022
Merci98
Afternoon, I would like to access my call log for September 22nd 2022, can someone explain how I can access this or if it can be sent to me?
thanks
mercy
@Merci98  Do you have itemised billing? If you don’t then you unfortunately can not see this information as it’s only available if you had/have itemised billing at that time.   Itemised billing can not be backdated if you was to set this up now. Your only option is to look at your device call history.
