08-04-2026 06:34 PM
trying to set up WiFi controls using the app and Smart hub 7 plus.
have just moved over from bt, the router is set up and connected and my speed is 1.0gb, which is all great ,But in order to fine tune you need to use the app, and every time it says to "set up wifi control" ,Start the process to set up WIFI controls but never gets past the first step (see photo).
08-04-2026 10:12 PM
just opened the ee app and while trying the wifi set up, i was giving the option to enter manually. This seems to have work as the app this fully working.
thank you for all your help
