Log on to bt hub
Bluesriff7
I am trying to log into my Bt hub 2
but tried using my EE app but it will
not par with the hub, the symbol just keeps
spinning , and tried 192.168.1.254 &
http://bthomehub.home
but safari saying connection is not secure
@Bluesriff7 Has been applied to the EE Smarthub 6 + and onwards as a https, never heard anyone mention as applied to your BT Smarthub2 or the EE equivalent version called the EE Smart Hub now. As you are with EE they may just not swap out your hub as deemed good enough for working.
7 REPLIES 7
Maestro
Maestro
@Bluesriff7 http://192.168.1.254 is the one and ignore safari security warning, other may be https://192.168.1.254 not sure if that hub has been FW updated to secure yet.
Bluesriff7
safari don't give you the option to ignore nut I tried duck duck go and managed to sign in.
looks like my hub is still http;// is there a update to https:// .
@Bluesriff7 If you cannot get to it with a https then NO.
Bluesriff7
Ok thanks for information , my broadband contract
runs out soon . So I will ask Ee about this issue
before I renew!
@Bluesriff7 wrote:
safari don't give you the option to ignore...
Safari does provide an option to ignore. The steps are detailed at the bottom of the article here.
Bluesriff7
just had a look at your information and tried safari and it works ok
thank you.
