09-04-2022 12:05 AM
I am trying to get an unlocked 4 g router work with a giffgaff sim. The 2 dont seem to work and i wonder if i need to change the Anp settings but cant really find the best way to do this despite having access to the admin settings. Any help would be appreciated!
09-04-2022 01:10 AM
If you completely disconnect the router from the mobile network & then re-connect it should auto populate the GG's APN. Even try taking the SIM out & then putting it back.
09-04-2022 02:29 AM
If its a New GiffGaff Sim it may not Auto configure the APN unless the Sim has been activated on a Mobile Device first, or wait at least 24 hours after activation.
APN Settings for GiffGaff Data are -
APN: giffgaff.com
Username: gg or leave blank
Password: p or leave blank
Proxy: leave blank
MCC: 234
MNC: 10
APN protocol: IPv4
APN roaming protocol: IPv4
Authentication type: PAP
