11-06-2025 10:14 PM
anyone else seeing packet loss to the fortnite servers from ee?
11-06-2025 10:27 PM
What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
11-06-2025 10:35 PM - edited 11-06-2025 10:36 PM
No!
11-06-2025 10:44 PM
What is the name of the EE BB plan are you on including its speed? 76MB i beleive. when trying to get package details from website i get "We’re having trouble displaying your profile details, It’s our fault, not yours. Please reload the page or try again later." even after a refresh
Which EE router & WiFi extenders, if any, do you have (read label or post a pix)? Smart Hub SH20A, No wifi extenders.
11-06-2025 10:48 PM
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
11-06-2025 11:10 PM
Advanced Settings > Technical Log > Information
Product code:Hub
Serial number:+112133+2228019443
Firmware version:v0.45.00.08028-BT
Firmware updated:Sat Apr 19 00:13:57 2025
Board version:R01
GUI version:1.80 11_07_2023
DSL uptime:13 days,00 Hours17 Mins18 Secs
Data rate:19.999 Mbps / 79.999 Mbps
Maximum data rate:26.117 Mbps / 83.550 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:15.1 / 4.5
Line attenuation:6.5 / 12.8
Signal attenuation:6.5 / 13.9
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:9.3 GB Uploaded / 386.5 GB Downloaded
Broadband username:obfiscated
Public Wi-fi status:Activated
2.4 GHz wireless network name:obfiscated
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:obfiscated
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:A8:A2:37:AE:74:2A
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
About Status Page
Connection status: Connected
Connection type:
Fibre Broadband (VDSL)
Firmware version:
v0.45.00.08028-BT
Firmware updated:
19-Apr-2025
Serial number:
+112133+2228019443
Downstream sync speed:
79.999 Mbps
Upstream sync speed:
19.999 Mbps
Network uptime:
13 Days, 00 Hours 21 Minutes
System uptime:
13 Days, 00 Hours 22 Minutes
Public Wi-fi status: Activated
12-06-2025 12:21 AM
Thanks. Was just checking your overall BB connection. It's fine & steady. Doesn't explain your packet loss.
What's WinMTR to bbc.co.uk like?
12-06-2025 08:51 AM
have you looked at hop 4?
12-06-2025 08:55 AM
looking at 62.172.102.78 on both MTR's its got packet loss. would there have been a issue in BT DC?
12-06-2025 11:41 AM
It's a BT node. It's got better things to do than respond to pings. It's got its own routing work to do. In my case it still passes everything on to the target.
