norton antivirus
david538
I have free Norton antivirus as part of my broadband entitlement.
I need to completely reinstall windows 11 on my desktop.
This will erase all my apps and files.
How do I reinstall my free Norton antivirus?
Alex_H
Hi @david538,
Welcome to the EE Community
If it is EE Cyber Security you have with the Norton antivirus included, if you have already activated it, which if you are using it now you have. Then to re-install it you would just log in to the EE website on the device you want to install it on, select Manage on Cyber Security and it will take you to Norton to download and install it.
There is a guide here you may find helpful when the time comes.
Alex
Alex_H
Hi @david538,
Alex
Alex_H
Thank you for your reply, However I am not seeing a link to Addons & Extras.
Can you advise me on how to move foreward, please.
David538
Alex_H
@david538 Are you able to access it and install it by logging in and following:
Select Manage.
Select Broadband.
Select Plan Details.
Select What’s included in your plan.
Select Cyber Security.
Alex
