my wifi is very poor
keeley76
my wifi is very poor please can you rectify this ASAP thanks
[Mod edit: Please do not post personal information on the public board. Thanks!]
Katie_J
Hello @keeley76
Welcome to the community.
Are all light on your router showing green?
Katie
