‎16-01-2023 09:06 AM
my home broadband which has worked fine and quick for so many years has now slowed dramatically from 60 mbps to 9 mbps. i have tested the line....reset the router...is it just me ???
rob from croydon, south london
‎16-01-2023 09:31 AM
‎18-01-2023 08:44 PM
hi
everything is sorted
a nice engineer from BT openreach came to my house and inspected the connection coming into the house.
it turned out that after 4 years from when a new connection plate was fitted it had over time gathered dust and moisture and some mould and rust on the wire connectors and so the signal went into limp mode as a safety mechanism as when there is some interference on the line it reduces the broadband speed for safety. after the engineer cleaned and reconnected the plate and wires everything was back to 100%...full speed. i will construct some box cover for the connector coming into the house as that will stop moisture and dust building up so quickly over time. thank you for the quick response and resolution of the issue.
‎19-01-2023 07:50 AM
Thanks for letting us know you got this sorted, @robbie4croydon.
I'm glad the engineer was able to spot this.
Jon
