landlines
makinb
i can use my landline since moving to digital but now find none of my four phones will connect when i call a service that has no options - which lets face it most companies use ! so called a travel company today pressed 1 for a new booking and got the message 'no digit selected' - this happened on all four phones and tried then a building socieyt and my surgery whicn have menu options and same problem
any ideas gratefully recevie
Maestro
Maestro
@makinb This type of fault has been reported before, if using the wireless adapter it does not work, but phones plugged into the back of the router do, and it could also possibly be the phone tone, not sure how you are connected but you can check and try. One OP is getting a new version of the remote adapter with possible FW update, but was only a couple of days ago so he has not posted back yet. HTH
