broadband problem
warthog
I have a broadband problem. Why do I have to talk to you via text? With all the money I'm giving you people im sure that you can afford to employ someone to answer the dam phone. I'm getting 2mb and paying for 36mb . also the mobile reception is lousy i get 1 bar reception sometimes. If I'm lucky i live in the Corvedale, SY7. Thank you
@warthog  So why don’t you call customer support because you can.
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
