30-10-2026 09:12 PM
As a customer can I access the public EE wifi around town? If yes, how?
30-10-2026 09:47 PM - edited 30-10-2026 09:49 PM
Yes, if you have fixed New EE Home BB (or BT BB) at home, you can use it for free from any mobile by logging @ Public EE WiFi with your EE BB a/c creds.
If you are not on New EE BB you can still use it but you will need to buy access.
Note that this is aside from WiFi Coverage Boost which includes WiFi on the London Underground.This is only available from EE mobiles.
30-10-2026 09:15 PM - edited 30-10-2026 09:39 PM
@Webpillow See here. And the other as well, or the absolute worst one if you find.
Using EE WiFi at Home and Out and About | Mobile Help | EE
Using WiFi Coverage Boost | Mobile Help | EE
Get public WiFi access | Find WiFi hotspots | EE WiFi
The last one is FREE to EE Broadband customers SO DO NOT be buying anything at all...... Use the Find a hotspot to locate either a Home full postcode, or a Business partial front part off the postcode....
