on 11-06-2026 11:06 AM
Hi ee since about 3pm yesterday the WiFi has gone from 40mbps to 15mbps and it does not seem to be changing I am hoping you are already trying to fix it please at least make a post saying your noticing the issues as it is becoming very difficult to do anything on the WiFi
Solved! Go to Solution.
11-06-2026 11:13 AM - edited 11-06-2026 11:18 AM
@Assassin5927558 Call EE CS, or run the service checker on your side, EE don't fix anything unless you let them know or if it is a KNOWN fault affecting an area that you are currently in.
ee.co.uk/help/contact-ee/technical-support/broadband-landline
on 11-06-2026 12:06 PM
Are you connected to 2.4GHz ,5GHz, 6GHz. Have you tried turning WiFi off on your device and then back on.
on 11-06-2026 01:16 PM
Yes I have tried turning it off and back on many times I have looked up many videos to try fix it and nothing has helped yet I will be calling EE to find out what's going on
