on 10-02-2025 04:27 PM
My wifi is slow and only get it in front room and i pay £38 a month
Solved! Go to Solution.
on 10-02-2025 06:54 PM
Good evening @Emmaxlxs.
Welcome to the EE Community 😊
Like @XRaySpeX mentioned your speeds will depend on the plan you've gone for, and with this you should have received an estimate, along with a minimum guaranteed speed.
If you haven't already, I'd recommend taking a look at our fault checker, which will test your connection, give you some troubleshooting steps, and if needs be help you get these issues investigated further.
Peter
on 10-02-2025 04:36 PM
Which EE BB plan are you on including its speed? What EE router do you have (read its label or post a pix)?
Peter
