Wifi keeps dropping in kitchen
Fre318
I’m new to EE TV & broadband & am using the TV via WiFi as there’s no easy way to run an Ethernet cable to the router due to where the BT Openreach box is installed (behind a cupboard door!). The TV box in the lounge works really well but the second box in the kitchen is intermittent as the wifi signal is weak & tends to dip out during the day but can then come back & work fine. I think I’ll need a booster to fix this & wondered if there’s any that would work best with a smart hub SH32B?
Thanks!
Profile closed
Not applicable
Not sure whether your Hub/Plan allows for foc extenders. Any wireless booster/extender needs a good wi-fi connection to work anyway.
Would any kind of ethernet powerline adaptor be any good?
Northerner
Hi @Fre318
Try changing your WiFi frequency.
