on 06-06-2024 07:54 PM
Instructions says it might take 5 minutes to connect, but it's been flashing blue for 4-5 hours. Is this normal??
on 06-06-2024 08:03 PM
Try Check service status for BB at your postcode.
on 06-06-2024 08:08 PM
@JNewnham1979 what is it you are trying to connect to?
Is this a new installation of broadband or are you trying to connect to something else?
on 06-06-2024 08:43 PM
just trying to connect a smart wifi plus device, to my smart hub, for the first time. they won't connect with each other...never ending blue flashing lights on the wifi plus device
on 06-06-2024 09:56 PM
@JNewnham1979 Link as below, try the ethernet info.
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
on 07-06-2024 11:09 AM
the smart wifi plus goes solid red, when connected via ethernet
on 07-06-2024 11:16 AM
@JNewnham1979 which model and colour router and smart wifi device do you have.
Not all are compatible with each other.
on 07-06-2024 11:21 AM
Hmmmm. Just checked my existing smart wifi plus, and it's a SW30A model. The second one is a SW10A model, which won't connect to my SH31B Hub.
on 07-06-2024 11:31 AM
@JNewnham1979 Ah, pretty sure the SW10A only works on older hubs.
Where did you get it from? Are you able to send it back and get a SW30A?
on 07-06-2024 11:34 AM
Thanks - got it all direct from BT/EE.....so I guess I'll have to spend 2 hours on the phone again, and wait for the correct kit. Thanks for your help.
