Wifi Extender 6 only connecting if using ethernet cable
coulson64
Hi, I have been using a Wifi extender for a while and now it will only connect to the hub if I use an ethernet cable.  It's been reset, etc. as per the EE instructions but still flashing blue continually.  Any advice?
Maestro
Maestro
Maestro
Maestro
