23-03-2024 02:27 PM
I have just moved across to EE 900mbs from BT 900mbs, on BT I had 3 wifi disks and was told that
I could keep these and use them on my new EE Smart Hub Plus. Unfortunately I am unable to get
them to work, they go through the fully cycle then the light turns a solid red. I am now thinking that
they are no compatible ? If thats the case then I may have to invoke the 14 day cooling off cancellation.
Can anyone advice please.
23-03-2024 02:31 PM
If they are the black BT Complete WiFi discs they are not compatible with the EE SH+. Only the white "high st" Whole Home disks were.
04-11-2024 04:38 PM
There seems to a pattern here, When I switched from BT to EE i mentioned my wifi disks (black) i was told they'd be ok by the engineer, i even showed him the locations and the disks. His response “oh yeh they're fine” well they're not fine they don't work with a ee hub. I’d guess ee know this and just spin their customers a line to get us to sign up!
