WiFi extender
Klm2009katie
Hi, I had my broadband installed today. The engineer needed to install the router in an area of my home which is not optimal for my TV set up. Can I get a WiFi extender for my living room pls? Thanks
Maestro
Maestro
@Klm2009katie You do not say what you have, so take a look at the smart wireless addon package, for an extra £10 per month, that will allow you to extend the wireless wifi signal. Other way is to look at a longer Ethernet cable from your new ONT to where you would like to position the EE Hub if that is possible to do.
