03-03-2024 08:39 PM
I appear to have the same problems as others with regards to WiFi controls .
I came from BT recently and initially had the controls but not anymore and have tried all the usual re install the app turn the router off etc to no avail. The speed is as expected so no problem there, is there a glitch in the software ?? also is there a fix or update due?. If EE has the fix please update everyone to when this will be available, because all I am reading on this forum is complaints about the controls not being available.
26-04-2024 11:59 AM
It looks like there are two different types of hub.
It seems the SH20A hub is a re-badged BT Smart Hub 2, which would have been deployed in the early days of the change over from BB ot EE.
The SH31B is the newer version and seems to have Wi-Fi 6 (IPV6 I think).
So it seems the "upgrade" you had shortly after getting the hub was when BT/EE made a change, not just to the firmware version but probably to the way your account worked.
Both support Fibre so why they won't give you a newer version is beyond me, but neither seem to work properly anyway!!!
My Broadband is FTTC and I have a SH31B version hub.
John I am assuming you have FTTP?
For info:-
FTTC means "Fibre To The Cab" and is where the service is provided via fibre connectivity to the cabinet in the street and then via copper wire into your home.
FTTP means Fibre to The Premises and is where the service is provided via a fibre feed direct into your home).
26-04-2024 01:19 PM
27-04-2024 08:40 AM
Well the TMC did actually ring me yesterday, at 5:pm.
No real update on my Wi-Fi controls problem, but they have fixed my emails.
For some reason my email addresses had reverted to basic service meaning I could only get to them via a web browser. It sounds like someone hadn't done their job properly in assigning them across to my EE account.
One problem resolved, one left to sort out.
27-04-2024 11:43 AM
30-04-2024 05:14 PM
Steve
new hub arrived not EE one but BT one after contacting help line which was BT I think they did something on remote access - I can see my devices now but not parental controls so Only partially working must have been the router.
07-05-2024 12:40 PM
Still no access to wifi controls after installing a new smart Hub.
07-05-2024 01:34 PM - edited 07-05-2024 01:34 PM
Absolutley no suprises at all. Its not the hub that is the issue, its the EE ID associated to the account that's the problem. Mine worked with the correct EE ID, once I switched back to my old and current one, it stopped.
11-05-2024 11:27 AM
I'm having the same problems moving from Sky to EE. Is Sky from BT too somehow?
21-09-2024 11:20 AM
This is not fixed.. it's not issue with BT hub or EE smart hub.. I tried with both and it's us not working.. it's definitely an app bug.. why can't EE give control via online account like BT ...why i have to use app which is not working.
21-09-2024 11:44 AM
@Sreejitnair123 The app works fine, (when it's working) and if not for you then you need to call EE CS for someone to take a look at why not for you.
