WiFi Smart Hub Pro on non fibre 1.6 deals
Spartacus123
Hi All,
I'm currently on an EE FTTP 900 connection, but the wifi coverage is poor, my house is solid brick and my current BT discs are dying - does anyone know if I can purchase a smart hub pro 7 and replace my smarthub 6?
I'M also waiting for a new power brick as my hub is the victim of whatever is going on with the smart hub 6's at the moment so this would be a good time to get a 7. Thanks
13 REPLIES 13
@Ewan15 Thanks for your reply was trying hard not too draw to much attention to it all! The 2.5Gb/s nic interface's can sometimes be that way when timing becomes that bit more critical between devices, so everything needs to be done just to give the helping hand, thought i would have had some issues with the son's 10Gb/s interface but no turned out to be rock solid on both the 10 and the 2.5, must just have hit that lucky streak!
Thanks @Scots_Man
Just what I was hoping to hear, essetially I'm going to do the same as I've seen some new on ebay so was hoping they would essentially be plug and go! Annoying that you need to pay extra for them tbh but my BT discs that ave server me well for a VERY long time are now dying so it looks like I'm in for a fun filled weekend.
Thanks again!
Hi @mikefairgrieve can I ask if you just did a plug and play then configured the hub via the portal? Same for the extenders?
Pretty much yeah, set it up and tweaked via the app but added the extender via the web portal.
