WiFi Smart Hub Pro on non fibre 1.6 deals
Spartacus123
Hi All,
I'm currently on an EE FTTP 900 connection, but the wifi coverage is poor, my house is solid brick and my current BT discs are dying - does anyone know if I can purchase a smart hub pro 7 and replace my smarthub 6?
I'M also waiting for a new power brick as my hub is the victim of whatever is going on with the smart hub 6's at the moment so this would be a good time to get a 7. Thanks
Scots_Man
Yes, I did the same. Roughly £40 on ebay for the smart hub pro and £50 per mesh wifi 7 repeater. They work out the box and will save you the monthly charges. The wifi 7 seems much stronger compared to the old kit with faster wifi pushed further around the house. It's a really affordable way to build a wifi 7 mesh network.
12 REPLIES 12
You can order as an extra the EE SH Pro for £7 pm on a 24 month contract.
Ewan15
Skilled Contributor
Skilled Contributor
@XRaySpeX  I am sure when I last checked Extender is now 10pcm and Pro (WIFI 7) is now £12pcm
Scots_Man
@Ewan15 : Yes, that would be correct when it includes Smart WiFi but I understood that just for the SH Pro alone would be £7 pm.
@Spartacus123 - if your house is solid brick then you’d be wise to be mindful of the fact the Pro devices use 6GHz for the hub <> extender communication. 6GHz is fast but it does not penetrate as well through walls etc. compared to the extenders from previous hubs.
@Scots_Man Any app or account problems the way you did it or not using etc?
mikefairgrieve
I did it the same way and only issue i have is the app shows my hub and extender as a Smart Hub Plus not a Pro including the pictures but everything else works fine ( Groups / Parental Controls ) and shows correct firmware etc.
@mikefairgrieve Thanks thought that may be the case, the Plus and the Pro are following each other fairly closely feature for feature so the FW and the App are going to be real close with each other, not able to work out which is which picture wise good chance then that is held external to the Router and on an EE Server!
Ewan15
Skilled Contributor
Skilled Contributor
@JimM11 The app until recently acknowledged that your device was the Smart Hub Pro in the section that tells you about your device and firmware version. Until very recently it said About your Smart Hub Pro, now it says About your Smart Hub Plus. However the firmware version is correct for the device you have (in my case the Pro, sourced from a third party). I can also confirm that the firmware updated when it was released around February, on both the Pro and it's extender.
I have experienced no issues on the 900mbs package, other that it is very sensitive to network cable quality.
