WiFi Pro Can’t Connect to Hub Pro
cturner77
I’m having some issues with my new WiFi Pro.
I set it up yesterday, and it worked fine, but the EE app said that it was not able to connect and the app still displayed that it wasn’t connected - Although it was connected and worked (I had the WiFi Pro wired to my Series X)
So now the problem starts. I had to switch the power socket as my second monitor had to be unplugged for it to fit, so I moved it over one to fit everything in.
since then, it just won’t connect over WPS via the app.
It flashes blue, then aqua then the app times out after about 10 minutes. The WiFi Pro just flashes Aqua and nothing happens
it’s not moved location since it worked earlier in the day, so I’m not sure why it won’t go solid!
Maestro
Maestro
@cturner77 Do not really know what your question is, the WPS has nothing to do with the app.
