01-07-2024 08:16 AM
Was a BT customer and have been xfered over to EE for Broadband and Mobile services. I used to be able to pick up EE Wi-Fi hotspots and log in using BT credentials but now the system prevents me from logging in using my EE credentials. Spent hours on the help desk phone line (even told that they don’t exist in my area, but my device finds them!). The log in screen just keeps refreshing when I try. Others in this group have similar issues. Apparently it works when you choose the option to pay!! Anyone had this problem resolved yet?
01-07-2024 09:28 AM
@Paulusmaximus : Do you have fixed Home BB or Mobile BB with EE?
01-07-2024 09:42 AM
01-07-2024 09:49 AM
@Paulusmaximus : Which EE BB plan are you on? What EE router do you have?
01-07-2024 09:58 AM
01-07-2024 10:00 AM
Yes, you should be able to use EE WiFi using your EE a/c creds.
01-07-2024 10:51 AM
04-07-2024 08:28 AM - edited 04-07-2024 08:29 AM
You have to 'opt in' not that it will do you any good because if you do the system will only opt you out again as soon as you leave the page.
It's here if you want to try it:
