Wi-Fi drop
ChaosInc
My wi fikeeps dropping to half every evening
@ChaosInc : What lights show on the router?
If it is a neighbourhood issue, you could consult Check service in your area  to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
Maestro
Maestro
@ChaosInc Do you also use the app speed test indicator to see what is happening when you get the speed drop on your service?
