Where on earth do you enter a WPS pin ???
DarrensEE
Ok, just got the smart router. Got a Samsung tv. Go to wireless and says use WPS, which I do then it’s generates a pin which has to be inputted into the router. Open the router settings on my computer but where on earth do you put this pin ?? Any help would be great before I launch everything through the window
@DarrensEE : There appears to be no WPS PINs, in either direction, with the EE Smart routers. Can't you do a manual WiFi connect by pressing the WPS button on the router & then telling the TV to use WPS?
robh661
I had the same problem, and the only way to get the Tv, which is also a Samsung to connect was to go though the app, and copy across my old router settings, which also renamed the router and password to the one I sent back.
