WhatsApp video calls poor over EE Wifi.
locky1
So I have recently moved from Virgin to EE  1.6GBS service.
Everything is fine I get 1690mbs down and 113up
The issue I have is the Video call quality on WhatsApp is shocking and keeps saying poor connection despite my phone getting 900mbs over Wifi.. I have tried the EE router and my Asus AX6000 and getting the same issue..
I have also tried it on different phones too and get the same issue..
I don't have the issue on my Virgin connection which I currently still have
thanks
axjx
Same boat. I just switched to EE from Virgin. Did you find any solution?
Community Hero
Community Hero
@axjx Won't be the same boat as the posted user due to the timescale and the equipment that was in use then, assume that you are on the EE Pro router and are you using any off the smart wireless extenders! VM do not offer that service unless you happened to be in a XGSPON area and using the 2Gb/s speed?
Daveharl
Hi.
I am experiencing exactly the same but no idea how to sort it, if their is an answer.
Any help appreciated.
Christopher_G
Hi @Daveharl
Welcome to the community.
I recommend trying a few things:
  1. Restart the device that the app is on
  2. Restart the router
  3. Make sure the app is on the latest version
Let us know if it's working any better after that please.
