Weekly router drop out
hbnghjdhnmgn
Every week my router drops out at least once, I have been having this issue for a few months. It drops for about a minute or two then comes back online, but this causes problems with my current working from home setup. I have made a note of the event log below after it happened again this morning:
07:35:27, 16 Aug. CWMP: HDM socket closed successfully.
07:35:27, 16 Aug. CWMP: HTTP authentication success from pbthdm.x.x.x
07:35:26, 16 Aug. CWMP: HDM socket opened successfully.
07:35:26, 16 Aug. CWMP: session completed successfully
07:35:26, 16 Aug. CWMP: HDM socket closed successfully.
07:35:26, 16 Aug. CWMP: HTTP authentication success from pbthdm.x.x.x
07:35:25, 16 Aug. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
07:35:25, 16 Aug. CWMP: Session start now, server: https://pbthdm.x.x.x, Event code:
07:35:25, 16 Aug. CWMP: Initializing transaction for event code 4 VALUE CHANGE
07:35:01, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:58, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:55, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:52, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:50, 16 Aug. NTP synchronization success
07:34:49, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:46, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:43, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:39, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:39, 16 Aug. WAN Sensing Auto sensing Complete, interface selected
07:34:37, 16 Aug. NTP synchronization start
07:34:37, 16 Aug. WAN DHCPv6 events: INIT
07:34:36, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:34, 16 Aug. WAN Sensing Auto sensing Running
07:34:34, 16 Aug. Success - secondary DNS servers
07:34:34, 16 Aug. Success - primary DNS servers
07:34:34, 16 Aug. WAN connection WAN2_INTERNET_PTM connected
07:34:34, 16 Aug. PPP: IPCP up
07:34:34, 16 Aug. PPP IPCP Receive Configuration ACK
07:34:34, 16 Aug. PPP IPCP Send Configuration Request
07:34:33, 16 Aug. PPP IPCP Receive Configuration NAK
07:34:33, 16 Aug. PPP IPCP Send Configuration ACK
07:34:33, 16 Aug. PPP IPCP Receive Configuration Request
07:34:33, 16 Aug. PPP IPV6CP Send Configuration Request
07:34:33, 16 Aug. PPP IPCP Send Configuration Request
07:34:33, 16 Aug. PPP: CHAP authentication succeeded
07:34:33, 16 Aug. PPP CHAP Receive success : authentication successful
07:34:33, 16 Aug. PPP CHAP Receive Challenge
07:34:33, 16 Aug. PPP: LCP up
07:34:33, 16 Aug. PPP LCP Receive Configuration ACK
07:34:33, 16 Aug. PPP LCP Send Configuration ACK
07:34:33, 16 Aug. PPP LCP Receive Configuration Request
07:34:33, 16 Aug. PPP LCP Send Configuration Request
07:34:33, 16 Aug. PPP: Received PADS
07:34:33, 16 Aug. PPP: Sending PADR
07:34:33, 16 Aug. PPP: Received PADO
07:34:33, 16 Aug. PPP: Sending PADI
07:34:28, 16 Aug. PPP: Sending PADI
07:34:23, 16 Aug. PPP: Sending PADI
07:34:17, 16 Aug. PPP: Sending PADI
07:34:12, 16 Aug. PPP: Sending PADI
07:34:07, 16 Aug. PPP: Sending PADI
07:34:02, 16 Aug. PPP: Starting PPP daemon
07:34:02, 16 Aug. WAN Auto-sensing detected port DSL WAN
07:34:02, 16 Aug. DSL Link Up: Down Rate=22132kbps, Up Rate=11786kbps; SNR Margin Down=4.6dB, Up=6.3dB
07:33:14, 16 Aug. PPP: Stopped PPP daemon(0,1,5)
07:33:14, 16 Aug. DSL Link Down: duration was 31 seconds
07:33:12, 16 Aug. PPP: Sending PADI
07:33:07, 16 Aug. PPP: Sending PADI
07:33:02, 16 Aug. PPP: Sending PADI
07:32:56, 16 Aug. PPP: Starting PPP daemon
07:32:56, 16 Aug. WAN Auto-sensing detected port DSL WAN
07:32:56, 16 Aug. DSL Link Up: Down Rate=31407kbps, Up Rate=9677kbps; SNR Margin Down=-5.8dB, Up=6.2dB
07:32:22, 16 Aug. WAN Sensing Auto sensing Complete, interface selected
07:32:22, 16 Aug. WAN Sensing Auto sensing Running
07:32:21, 16 Aug. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
07:32:15, 16 Aug. PPP: Stopped PPP daemon(0,1,5)
07:32:12, 16 Aug. PPP LCP Send Termination Request (User request)
07:32:09, 16 Aug. PPP LCP Send Termination Request (User request)
07:32:09, 16 Aug. PPP: IPCP down
07:32:09, 16 Aug. PPP: LCP down
07:32:09, 16 Aug. DSL Link Down: duration was 1283 seconds
7 REPLIES 7
Mustrum
@hbnghjdhnmgn  most of the entries in your post don't really help, are you able to filter the log to include just the WAN ones and post a CSV file over a much longer period. That would give more of an idea of how often the problem occurs.
Also do you dtill have a phone plugged in? If so dial 17070 option 2 and let us know if you hear any noise.
Or you could give the Broadband Care Team a call to see if they can help.
Thank you, I have uploaded the WAN log and router info to https://filebin.net/hafpofm36lku8fcf
I do not have a phone plugged in as I am on a Broadband only contract.
Unfortunately I am unable to speak over the phone at the moment, but will call the Broadband team on Monday if I am still having issues.
@hbnghjdhnmgn    your broadband is dropping a lot more than you implied in your first post, and even the speeds vary quite a lot.
Were it me I would try the check broadband link here https://ee.co.uk/help/broadband
And if that does not find anything try the txt service or call here https://ee.co.uk/help/contact-ee/technical-support/broadband-landline
Mooly01
Not sure if this helps or not but both EE (and BT) routers do automatically reboot to a schedule. I think it used to be weekly when I was with BT but somewhere down the line that became every 14 days.
It is as regular as clockwork (to within a couple of hours) and something that has been commented on before. This happened with BT and a Smart Hub 2  and also I notice with EE and their Smart Hub when I was transferred.
@Mooly01 : Really? It could well be on BT which I've never used but I've never seen it on EE, on FTTC which this is. Haven't rebooted for weeks.
Mustrum
@Mooly01   thanks, yes I too am aware of the BT based Routers/Hubs that like to reboot every two weeks, however in this case the issue appears to be frequent disconnects. Hopefully we will hear more from the OP.
