WPS Connection
cheshirecheese1
Can not turn on WPS on the HUB because security is set to WPA3-Personal
10 REPLIES 10
Dabmonger
"Factory reset the hub by inserting something into the reset pinhole at the rear until the LED goes green and it reboots"
I was just wondering why a factory reset of both the hub and printer would be required in this case?
And in the case of connecting a DVA with a smart hub plus, does pressing the WPS START button in the GUI under Compatible WiFi lead to the exact same process as physically pressing the WPS button on the side of the hub?
Or is the WPS button on the hub using a hybrid WPA2/WPA3-Personal setting for the DVA, and could this work for other devices too?
It would seem that pressing WPS Start in Compatible WiFi in the GUI is the same as physically pressing the WPS button when connecting a DVA to the hub. I'll give it a go as I'm interested 🙂
