WIFI Extender 7 Pro flashes orange on and off
paulmcf121318
Hi  We've had this persistent issue with our WIFI extender where it will disconnect and flash orange, and then connect again back to blue.  It does this consistently every 30 mins or so.
I've moved the extender closer to the hub to test and get the same issue.  Its been reset and rebooted with no improvement.
Does anyone have any ideas?  The main hub runs like a dream its just the extender that is the issue.
Northerner
Hi @paulmcf121318
Do you need them. WiFi 7 improves signal and extenders may not be needed or causing conflicts.
Which router and extenders do you own.
